1 - 5 of 5 Posts
I have a 1999 Esprit 3.5 and I need an oil pressure sending unit. I have read here before you can obtain locally, and my local parts store got me one that was the correct thread and said it was 2 psi different then factory. The problem is it reads backwards, light OFF on start up then ON with pressure. Any help would be great.
I found a discussion online that the oil pressure sender for the 4 cylinder Esprit has 2 pins, one for the gauge and one for the light. That person used just one of them to drive the oil pressure light on a V8, and the threads allowed it to be installed in the original V8 switch location. Has anyone here done that?
If the pressure threshold is right, sounds like you just need a switch that's normally open instead of normally closed.
Take it to NAPA or any other good local auto parts store and they should be able to figure it out.
1 - 5 of 5 Posts
