1 - 2 of 2 Posts
I have noticed recently that my oil pressure tell tale lamp flickers a little bit when the engine is not running but ignition is on (when I check the bulbs). Sometimes it is fine and lights solidly - then others it flickers - then back to solid. Presumably this is a problem with the bulb or circuit as it does not light at all when engine is running - and the car is running fine, with plenty of oil.
Is there an easy way to check/fix this? Any advice much appreciated as usual.
Martin
1 - 2 of 2 Posts
