As part of my SC install experience, I figured I may as well do some gauges while I was at it.
I decided to install an Oil Pressure and Oil Temperature Gauge setup. I chose DEFI gauges, Blue Racer models. My car is Mag Blue, so the color choice seemed appropriate.
The quality of the gauges is excellent, but what really impressed me was the caliber of the sensors and connecting wires. These are all OEM grade components, nothing DIY about it.
I did have to buy an oil filter sandwich plate, which I got from Maxspeed - Motorsports. Blue anodized aluminum, CNC-milled component with 3 1/8 NPT fitting positions. Shipped price was $46.99. Excellent quality and fits perfectly on the engine.
Install was pretty simple. Plate fit in place with no issues. I plumbed the 2 sensors (pressure and temp) easily. Tip: Put these on the sandwich plate BEFORE installing the plate itself onto the engine. Makes it easier to align everything.
I ran the sensor cables through the hand brake cable tunnel, into the cabin, between the seats and up the shifter console to the 3-hole aluminum piece under the dash.
The power cables come the other way, from the lighting switch panel (for ignition on power, dimmer/illumination lamps). I used several of the wire connections under the dash (+12 Volt Power, Ground) to finish the wiring. Sensor and Power wires snap into back of the gauges. Power is universal to the gauges, specific sensor wire is unique to each gauge type.
I picked up a BWR gauge pod holder/bracket from a fellow LTer and the gauges fit perfectly into the openings.
Cleaned up the rats nest of wires under the dash with some wire ties and cable loom. Everything works fine.
I thought the gauges might be a little low and out of my primary line of sight. However, they are so easy to read and even if you can't get the actual number reading, you know where you are on the scale, so it's quite helpful.
With an SC set-up, I feel better having the extra information about oil pressure and temperature.
A few pics included to show the set-up.
Regards,
Wayne
Regards,
Wayne
