All shims out. Still only get -1.0 deg both sides. Everyone says machine vall joint carrier (rectangular block to which the hub carrier bolts. In the parts diags, this is group 31.03 key #4. If the pic is accurate, it looks like this block is drilled off center for the ball joint. Is this true? If so, can it be rotated 180 degrees, making it shorter toward the outside then shimmed to correct geometry, rather than milling off the outer surface?
