1 - 20 of 27 Posts
NSFW - Some bad language right at the start.
1st run: [email protected]
2nd run: [email protected]
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/wXkwMsPi-ao&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/wXkwMsPi-ao&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
Hell im turbo and id still be ashamed to drag race the elise....too many cheap hondas,nissans, and mustangs with 400+hp around here.
That looks like an "S" to me. Small scoop on the roof.
Funny to hear all the "Psssst" turbo blowoff sounds in the background...
Cheers
Skottoman
I probably wouldn't try it on the stock clutch, but maybe a more upgraded one. Also, isn't there someone else who was hitting deep low 13s on a stock Elise/Exige?
Has anyone with an actual Exige S ever tracked it once just to see? I'm curious.
stock exige S here.
I took mine to the drag strip with an evo friend of mine.
I only ran once.
Terrible launch, my trac control i think kicked in.
Still ran a respectable 13.85 though.
I would suspect with some tweaking/practice low 13's easy.
stock exige S here.
I only ran once.
Seems the Exige S is quite a bit more capable than that. Magazines have managed mid 12s out of it.
Ive read that as well.
Its probably the launch. I believe our cars are a lot like the s2000.
To get a good drag out of it you need to rev it to 7k plus rpms. and dump the clutch. Something i didnt want to do.
3k rpm launch from me.
I hit 13.180 @ 102.70mph bone stock back in Fall 2005: http://www.lotustalk.com/forums/266029-post77.html
Driver makes all the difference!
I was told I couldnt break 14s in a miata with bolt ons and I did
I was told I couldnt get a sub 2sec 60ft in my 300z(Non turbo) and I did
Some people, even ones who are good on circuits, are bad with the clutch and shifting. I believe magazine times are all higher than whats capable after someone gets a good feel for their car. Those guys may be good drivers, but experience in each car can improve times.
Oh and it says "s/c" on his windshield under his car number...not a sure indicator it was supercharged, but judging from the weak launches those numbers would be pretty consistent with a supercharged car.
So if i tell you you can break into the 11's with a stock elise will you do it after some expierence?
I started out as a drag racer in a 5.0 Mustang. To make it turn quick times, I had to abuse the crap out of it--rev to 5000 rpm, slip (not dump) the clutch, and speed shift. Speed shifting alone is worth two tenths, but it kills the drivetrain.
Not something I'd want to do to my Exige.
Terry
1 - 20 of 27 Posts
