1 - 16 of 16 Posts
A1 Automotive & Smog
A friend of mine selling his 2006 Lotus Exige, it has salvaged title due to rear end hit. Chassis looks straight, suspension looks good, it has track pack Bilstein adjustable suspension. The front clam & hard-top has been removed as well. Base on the pictures, can you give me estimate on what's the fair price to purchase?
Tire Wheel Vehicle Automotive tire Hood
Motor vehicle Car Automotive design Automotive air manifold Automotive tire
Tire Wheel Motor vehicle Automotive tire Tread
Tire Wheel Vehicle Car Hood
Tire Wheel Automotive tire Hood Tread
Tire Wheel Car Land vehicle Vehicle
Tire Wheel Car Vehicle Hood
Car Automotive tire Hood Motor vehicle Automotive design
Wheel Tire Car Vehicle Hood
Are the front clam and roof included with the sale and in good condition? That looks like a mess, to be honest. Looks like a few different projects were started and then abandoned. Factory rad is a ticking bomb. No info on miles or interior condition. I’d say $25k is generous in light of all the unknowns and with a present market adjustment.
2005 Elise
If it is as is, I see at least 12k in clams and probably the same in prep and paint. To me it needs at least 25k in work.
So depending on miles and otherwise condition…
Administrator
Rough
2005 Lotus Elise
Do the pulled off parts come with it? Looks like a mess unless you have the funds and knowledge to tackle a project like this. At least the clams are already off so that saves you a few hours.
Reactions: bucket
2006 Exige
Not enough information to tell what’s it’s worth.
No pictures of rear clam?Does it run,is transmission ok. The muffler mounts are undamaged so it may not have been hit hard.You need to do your due diligence before posting.
Reactions: Harix
My opinion is that unless you have deep pockets and can do a lot of your own wrenching, don’t risk your friendship.
Reactions: JMack77 and Harix
A bit of insight here to help @Harix. For those that may not know, Harry is a highly recommended repair destination for Eliges in So Cal. However, Harry may not have his fingers on the pulse of values as much as he is usually repairing them mechanically, not trading them.
The only thing I can "see" that looks odd to me is the base wheels on it and I believe Exiges never came with them.
I ask, as I don't know, but are the 06 N/A Exiges identical to LSS Elises other than the clams? (Under the skin)
Front crash box is cracked driver side top
Clams
Rear subframe looks bent at the rust/corrosion spot
Hardtop
if you have these parts, it’s a simple repair, just time.
paint will be 3-7k at a shop like LTMW.
if you factor it going for ~45k when repaired, work backwards on the above parts and see if your friend will give you a decent enough price on it all.
2006 Exige
The only thing I can "see" that looks odd to me is the base wheels on it and I believe Exiges never came them.
Yes, those wheels were only on the Elise.
Yes, they are pretty much the same except for a couple minor differences. You can tell this was/is an Exige because of the plastic piece below the rear window. The seats would obviously be different too, but we can't see those.
That thing is a right mess, but fixable. The plastic radiator is the least of that car's probs.
Honestly it’s slot of work, if you enjoy projects and can do most of the work yourself. I’ll would play it safe and offer 18k, he is selling a project and for whatever reason he didn’t finish it.
This was my thought as well. Lots of possible gremlins.
Looks like it's been sitting outside, in the elements, with the clams removed. I'd be a bit concerned with corrosion in some of harness and any areas where moisture could have crept in through wire seals in connectors.
My $0.02...
As many know all too well, the pricing on used cars has gone insane lately. Unless you're planning to QUICKLY flip this car or can get it for the old salvage yard pricing ~25k I would steer clear. Otherwise by the time you're done, you might have as well bought a used Lotus and just driven it instead of wrenching for 100s of hours.
Forgot to ask.. I noticed the coolant expansion tank and exhaust are removed and, I think, the fuel line is disconnected. Seems odd, I would ensure you have the full story on the extent of the damage including that which took place after the wreck.
Reactions: Catsailr27
Administrator
I know who Harry is and what he's capable of and the way it came across was he was asking for someone to get opinions other than his. Maybe a friend? Too many unknowns as others pointed out plus the known issues. Without knowing more <$20k
1 - 16 of 16 Posts
