If you check your local area for a professional auto body supply, they should have a textured coating in a spray can you can use to duplicate the finish. Its like a light grainy finish, sorta like 1000 grit sand paper, maybe finer. You can almost make it finer and coarser by how you spray it. I bought that product once or twice in the past, its usually black or grey, then you just paint it the color you would like over top. I considering using it on my engine cover, because the color of it looked old compared to the new black carpet I put on the left and right inside the sail panel window areas.
