Always been a Toyota engine in the US.
It comes with the Toyota transmission that is usally mounted with the engine in the Celica GTS. 6-speed. Only difference I am aware of beween the Celica and ours is that 6th gear isnt as tall in our version. Someone correct me if I am wrong.and what transmission does the Elise have? i believe someone said its also from Toyota, but i thought i read somewhere that its a Ford transmission now?
Mike
Yes and no. The Lotus uses the European version of the Celica GTS engine and transmission. The US version has a different sixth speed gear ratio - we use the European version.It comes with the Toyota transmission that is usally mounted with the engine in the Celica GTS. 6-speed. Only difference I am aware of beween the Celica and ours is that 6th gear isnt as tall in our version. Someone correct me if I am wrong.
C60 and C64, I believe?Yes and no. The Lotus uses the European version of the Celica GTS engine and transmission. The US version has a different sixth speed gear ratio - we use the European version.
What makes you think its a ford transmission on a toyota engine??????????? And why would a ford transmission fit on a toyota engine?and what transmission does the Elise have? i believe someone said its also from Toyota, but i thought i read somewhere that its a Ford transmission now?
Mike
Maybe it's more a Ford Transmission on a Lotus - which some did in the past - my Elan has a Ford transmission (as well as engine block)...What makes you think its a ford transmission on a toyota engine?
The S2 was introduced in 2000.before introducing the vehicle to the US in '04/'05, Lotus changed the body style currently known as the S2.
My Seven also has a Ford transmission, block, differential, rear axle...Maybe it's more a Ford Transmission on a Lotus - which some did in the past - my Elan has a Ford transmission (as well as engine block)...
ok, this is going to be a stupid question. but i didnt know Toyota made the Celica anymore? i thought the Yaris and Corolla were the small cars made by Toyota.It comes with the Toyota transmission that is usally mounted with the engine in the Celica GTS. 6-speed. Only difference I am aware of beween the Celica and ours is that 6th gear isnt as tall in our version. Someone correct me if I am wrong.
Answers are always hereok, this is going to be a stupid question. but i didnt know Toyota made the Celica anymore? i thought the Yaris and Corolla were the small cars made by Toyota.
M
...before introducing the vehicle to the US in '04/'05, Lotus changed the body style currently known as the S2.
Uh... yeah. That's before '04/'05 ain't it?The S2 was introduced in 2000.
That certainly does sound rather retarded no? A Ford tranny?What makes you think its a ford transmission on a toyota engine??????????? And why would a ford transmission fit on a toyota engine?
