1 - 4 of 4 Posts
I have been reading threads on the CDL issues, and while it may be my issue, I am not sure. My driver side door works fine, but my passenger door will not lock or unlock with the remote. I see the peg jiggle a little when I use the remote, but it doesn't fully move. Would this also be the CDL since only one door is behaving improperly? I could not find many individuals that fixed their issue with one door, most of the issues seem to appear with both doors. I didn't want to rip the door apart or order parts until I had more information. Anyone have any ideas on what to check? Thanks in advance
I would think that if the peg is jiggling, that the CDL is ok. Either the solenoid in that door is dying or the linkage is messed up
Are you sure that door wasn't locked with the key??????
I will take the door apart and look for any loose connections. I don't believe I have ever used the key for the doors, but I can check that as well. Now that it is finally warm out, I can do some checking. I just wasn't sure since it was happening on one side of the car and not the other. Thanks for the replies.
1 - 4 of 4 Posts
