1 - 3 of 3 Posts
The fuses under the dash on the passenger side are just flopping around near the passenger's feet. Is there somewhere those two fuse blocks are supposed to clip into or attach to? I can't seem to find anywhere they're supposed to go. Currently the blocks are just dangling from the wire bundles. I could zip tie them out of the way, but that won't look so good.
give me my second cam!
I believe thats how they all are. Mine is the same way...TADTS I forget what the fuses go to maybe someone else can chime in on that.
Such Moderate
Just zip tie the fuse block up under there. You won't be able to see it at all unless you are under the dash.
1 - 3 of 3 Posts
