posting this here for the greater group consumption. The white plug is only a few inches off of the crossover, which is hidden up against the chassis below the a pillar, underneath the leather panel that goes from the door sill to the dash panel. Same on both sides, and same on both sides, removal of this panel (if my memory serves me correct) requires removing the door sill, the knee pad (up under the dash or steering wheel, held in place by two allen bolts) and then the screws/trim clips will be visible, and that panel comes right out.
The wiring runs from the tweeter, down through the rubber grommets/hose that goes through the AC ducting, and through an access port that is hidden unless you have that panel off to the crossover. The rubber tubing that is in the AC ducting appears to be heat shrink IIRC, so I am not sure even if you disassembled the panels, unplugged the clip, you could readily pull the wiring up through without damaging this tubing. FWIW when I replaced my stereo with better speaker wire and new drivers throughout, I didn't bother using heat shrink tubing to cover the wire running through it.
That leaves you with two options-remove the tubing, after which youll see the black/red wiring if you look up the AC duct (not really noticeable unless you're looking for it) or you could try to redo the heatshrink tubing (not that hard really), or you can cut the wiring and resolder into the old wiring-you could likely accomplish this without taking anything apart besides pulling the tweeter out.
In this pic, if you look closely, you can see the white connector hanging through the dash hanging just above the crossover. I had cut the tweeter wiring at this point so there is no tweeter at the other end.
