For Sale: The Egg, manufactured by Jason Industries is a cargo carrier with a eight by four foot cargo area. You could sleep in it, but suffocate without air. THE EGG
Standard
* White Exterior Finish
* Powder Coated Steel Frame
* Stainless Steel Exterior Hinges
* Jason's Exclusive Oval Twist Lock Handle
* 4 - Plug Wire Harness
* 12 Volt Interior Light
The SSR is not for sale. But if you want it, bring an additional twenty eight thousand dollars.
* Rear Mounted Pull Strap
* Built-In Support to Split Cargo
* Interior Drain Plug
* 4 Cargo Tie Downs
* L.E.D. Tail Lights
* Torsion Bar Suspension
* Side Marker Lights
* License Plate Light
* Jack Stand
* 2" Coupler
Optional
* Automotive Painted Finish to Asphalt Black
* Aluminum Chassis
* Alumium / Mag Wheels
* Spare Tire and Carrier
* Carpet Interior - Black
* 69.8 cu. ft. cargo area.
It was manufactured on 6/20/06, GVWR 519 KG, 1145 LB., GAWR ALL 907 KG (2000/AXLE with ST175/80 R13 tire 13X4 5JB rim at 345 KPA (50 PSI) cold single.
We used it for a trip from Texas to California and it tows easily. We are selling it because there is a substantial lip that you must lift cargo over to place inside. One of our main cargo items is an EX Pop Up tent that weighs well over 150 lbs. Because of recent restrictions in lifting habits we need to look for a cargo hauler with a ramp.
A fair price is three thousand, two hundred and fifty dollars ($3,250.00). This is less than we paid for it. The invoice was for four thousand and five dollars, but part of the expense was the hitch and state sales tax.
Specs.: Gross Weight 290 lbs.
Ext. Length 88"
Ext. Width 69"
Ext. Box Height 28" (Interior Box Height is slightly less than 28")
Max. Load 1700 lbs.
Hitch Weight (dry) 30 lbs.
Overall Length 119"
Axel Rating 2000 lbs.
Overall Heigth 42"
Standard
* 4 Cargo Tie Downs
* Jack Stand
* 2" Coupler
Optional
* Aluminum Chassis
Ext. Length 88"
Ext. Width 69"
Max. Load 1700 lbs.
Overall Length 119"
Overall Heigth 42"
