61 - 80 of 95 Posts
Footwell
NevB,
I have been posting on another thread regarding pedal spacing. I have large feet and found that the show car I sat in didn't allow enough space between the brake and center brace for my foot to reach the gas. I exchanged email with development manager Nick Adams about this. Here was one of his suggestions:
"Alternatively it may be possible to fit a RHD divider from a European 111R, which is lower and should offer more space although passengers would have to be told to control their feet! Your dealer should be able to get this part for you as a special order, the part number is A116A0147F. "
I saw the picture of your footwell in this thread, and was hoping you could do me a HUGE favor. Any chance you could measure the height of the divider? I hope to test drive the demo in Atlanta in another month or two, and would like to know whether I should give up on my dream car.
Houston!......I mean San Diego......We
have a problem! Over 4.5 won't compute.
Need mid-course correction plan that can
assist proper fitment.
Discussion Starter #63
Re: Footwell
scmcclure said:
NevB,
Hi scmcclure ,
Hope this diagram helps:
<6cm>
I......\
I.......\
I........\
I.........\
< 10cm >
Cheers
Nev
Discussion Starter #65 (Edited)
2nd attempt
<6cm>
I......\.............................O
I.......\............................II
I........\ -------------------II-----
I.........\
< 10cm >
The wedge at the pedals is 6cm deep at the top of the toe, and 10cm at the base of the heel. The gear stick is another 50cm [guess] down the centre console
You lost me. I was trying to find the height of the center divider. On your car this would separate the passenger's feet from the clutch or dead pedal. I wasn't sure what you were measuring from the "heal" or "toe."
Just measured mine - it's about 10cm - 11cm high so your foot should be able to slide across the top. I have size 11s and wear wide leather soled shoes to work and don't have any problems although obviously my car is RHD.
Thanks! I just did the cm-in conversion and your footwell divider is roughly the height of my coffee mug. Should have no trouble maneuvering over that!
Do you have any pictures of your RHD footwell similar to this one from a LHD Elise?
It's for safety. The danger is that on the LHD the passenger's feet may hit the gas. On the RHD their feet would hit the dead pedal or possibly the clutch. Not as big a deal.
I don't know if this is required per US regulations or just common practice on LHD models. It seems like I've been in many front-wheel-drive cars that have nothing between the passenger's feet and the gas pedal, but I honestly can't remember. Our 82 Dodge Aries K comes to mind. With front-wheel-drive, a front bench seat, and the transmission on the steering column, I can't imagine there was any barrier there.
But even if they did not have a barrier, I have never been in a car where the passenger and driver sit so close together!
Nev or anyone else in Oz::
Have you take off the rear diffuser to see where the oil filter is located? Is it easily accessible for changing or go you need to wiggle around and have trouble getting to it.
Also is the airfilter the standard Celica one. I was thinking about getting a K&N filter, but dont know if Lotus changed it to one of their own design.
You have to take of the aluminium panels on the bottom of the car in front of the diffuser (underneath the engine) to gain access to sump to drain the oil and get access to the filter.
You don't have to take the diffuser off.
The airfilter is at the left hand front of the engine. It is a disposable folded paper type. Not sure if it's the same on the Celica but I doubt it. For access to it you need to remove the left hand back wheel and the wheel arch liner.
scmcclure said:
Older cars with a front bench seat put the middle passenger right on top of the driver.
The same thing happened on dates without a middle passenger. :D ;)
61 - 80 of 95 Posts
