Just wanted to share the progress of my dash install. I'm using the brackets made by Brent Bauman. It is a SUPER clean and easy install. You only have to tap 4 wires from the stock cluster harness(+/- power and +/- CAN) and you get you your standard dash functions(fuel level, water temp, rpm, speed,... etc.) Then you can add whichever extra AiM sensors that you like for your setup. The bracket bolts right inplace of the factory cluster using the same 4 holes. There is a different bracket for the 211 but it is also done.
I previously had a racepack G2X data logger and display, a Defi display, and a separate IC temp gauge and have removed all of it in favor of just the dash. It will be MUCH nice to have everything in one place with no extra control boxes mounted to the floor.
The front and back of the bracket with a carbon veneer:
fit into the binnacle:
I haven't gotten to installing mine into the dash yet but I will next week. Here is a photo of what it looks like in Brents car. The same bracket:
This is a diagram I put together of the setup I'm going with
