1 - 11 of 11 Posts
So I have been having an intermittent ABS light for the last 6 months or so... After I did my "go-cart" track day with lots on heavy breaking and twisty stuff the light has been off ever since. Does anyone have a clue of what may be the issue if any at all? :scratchhead:
and no I have not made any mods to the breaks except for DBS rotors and Ferodo pads about 2 years ago. No problems existed till recently with the light on.
Having an ABS light on is as ambiguous as having a check engine light - you really need to plug in and see what error is being reported. The problem though is that we don't have a readily available scan tool, so everyone reverts to a guessing game. The likely culprits are usually loose wires - wheel speed, power, brake sensor, etc. A loose wire could've been jarred in a way to make it tight again, too, but again it is a billion times easier to just have the stored code(s) read.
^So is a dealer/service the only way to get the code scanned?
I'm not really sure what you're options are, but it at least gives you a search term to try and see how people have done it in the past. Maybe someone figured out a cross-reference that works. Despite how much I hate a bad diagnostic approach, I hate going to dealers even more. I looked in the service manual, and it is intentionally vague about the codes, but I think these are the options available:
BATTERY VOLTAGE System voltage
BRAKE LIGHT SW. Brake light switch
FL WHEEL SPEED Front left wheel speed
FR WHEEL SPEED Front right wheel speed
RL WHEEL SPEED Rear right wheel speed
RR WHEEL SPEED Rear right wheel speed
FRONT WHL SPEEDS Front wheel speed
REAR WHL SPEEDS Rear wheel speed
That's a pretty easy list to troubleshoot, but then again you don't actively have a problem. If you go around yanking wires to find which one was loose, you might end up just creating a new problem. Until the light comes back on, I think you're best two options are to go to a dealer or to pretend nothing ever happened. I'd lean towards the latter, honestly, if a visual inspection doesn't show anything obvious.
^Thanks for the info!
My ABS light started to come on a couple of years ago sort of randomly. It degenerated over perhaps a year and now it is generally ON all of the time.
Every once in a while it will be off for 1/2 hour of driving.
I did have the dealer look at it and they said it might be a defective ABS module, but admitted they were not sure.
I cleaned the contacts at the wheel sensors and also cleaned up the cable that plugs into the ABS module but that did not help.
I am guessing that in my case it is flaky wiring or a bad ABS module but I've decided to give up on fixing it.
Do you or anyone know if the ABS will still function with leaving the light "ON"? Or should I test this on some dirt/gravel?
Illegal Alien
I would test it out as under some faults it may disable itself.
ABS
My ABS would not work when the light was on. I did recently send my module to Inokinetic. They rebuilt it and sent it back. No more light and the ABS works again!
No, I think Inokinetic charged $199. Getting it out required front clam removal but I used that opportunity to replace the radiator too
1 - 11 of 11 Posts
