1 - 8 of 8 Posts
My '05 Elise has developed a problem where it pops out of 6th gear. It started probably less than 500 miles ago, when I was steady state cruising in 6th. All of a sudden it popped out of gear, into Neutral. I could deliberately and put it back into 6th with slow "side then back" movement, and it would usually stay for quite a while.
This issue would continue over the next maybe 100-200 miles, popping out after a recent 5-6 gear change and then staying in with the deliberate 6th gear afterwards.
Then, it quickly got worse. The deliberate 6th stopped working to the point where it would soon pop back out.
Then, shortly after 6th gear became impossible. Now, it is to the point where I can be off throttle, do a slow and deliberate 6th gear engagement. It WILL coast in gear, but the second any throttle is applied it pops out - like immediately. But now, rather than being in just neutral it grinds until I clutch and push it all the way into neutral or into another gear. All other gears work, including Reverse.
Probably of relevance, when I bought the car it would grind going into 2nd. Both upshifts or down, and I would have to double clutch to use second. It was fixed when I had the gearbox syncros replaced shortly after purchase, maybe 2000-3000 miles ago. A trans shop did the full job, with parts from Monkeywrench racing.
More recently, I installed a LETSLA shifter linkage about 1500-1000 miles ago. It seemed to shift well for a good while, until this 6th gear issue developed.
Just today, I messed with the cable adjustments on the shifter. Adjusting the shift cable and the cross cable did not seem to have any effect.
Anybody have any ideas? I'm gonna be really upset if my syncros or something internal to the trans is broken again.
It's the dog teeth in the trans. It will need pulled to replace the gears, sorry. It's the easiest thing in the trans to do, but you should probably change everything while you are in there.
Damn...By everything...whats everything? Like I said the syncros are very new.
Well if you're talking under 10000? miles and no tracking then sure, just have them/you pop off that last case and change what needs done, you can get the lotus gears for about $500 or the toyota gears for $150? Make sure that your shifter is adjusted so that the shifter on the trans can stay where it wants to be when in 6th when you reassemble, make sure there is no "preload".
interesting topic, I notice my 6th gear doesn't quite "lock-in" either when I shift into it and sometime I had to double check myself to make sure I'm in gear because it doesn't have the "click" feel going into 6th gear, is my gear going bad? or is that normal?
where can I get this "toyota gears" you speak of? is there a diagram or model number you could share with me please?
thanks
I think the fact that the OP had the linkage apart is a red flag. Before pulling the trans I would be in there looking at how everything is adjusted
I agree. Much easier & less expensive to experiment with linkage and cable adjustment as the next step.
As I think about it, while it could certainly be serious internal trouble.....
the 2-4-6 gate is pushing, a less efficient cable movement
over in 6 it is bending the shifter cable end a fair bit, making it less efficient than 2 and 4
if something is loose on the trans end, it may exhibit this way, anything from a loose bolt to a bad cable end clip
Prior to putting the letsa[modified] in my car the only real shifting I had was 6th gear, which was, I think, rubbing against the console making it slip into 4th more easily than 6th
1 - 8 of 8 Posts
