Okay Wek120, you are killin' me. Lets make some basic assumptions to start with.
1. You find an LED which has an operating voltage of 2 volts, and an operating current of 20mA or 0.02 amps.
2. Assume you want it fully illuminated at 12 volts (13.8volts is probably your actual)
This means you have an EXTRA 10 volts you must lose across a resister to keep from burning out the LED. (12 volts available, LED needs 2v, must lose 10v)
10 volts, 20ma (or 0.02 amps) "dissapated" across the resister. R (the value of the resister in ohms equals E (the voltage you want to lose across the resister, assumed 10 volts) divided by I (the current required to fully illuminate the LED 20ma or 0.02 amps)
10/.02 = 500 ohms. The resister will always lose some voltage, so when you apply 2.5 volts across the resister which is in series with the LED you will not have enough voltage and current to illuminate the LED. Another route which provides a knife-edge transition from off to on; place two 5.3 volt zener diodes in series with the LED, the zeners will "lose" a total of 10.6 volts, so the voltage must exceed 10.6 volts before the LED sees even a single volt. (caution: make sure the band on them (cathode) is faced the correct direction or the voltage drop will only be 1.2 volts (frying the LED), instead of the intended 10.6 volts)
But all of this aside, if you cannot hear or feel your second cam kick in, then you may have an actual problem with your car (broken lift bolt comes to mind), OR, have a tune which has lowered the cam changeover to slightly below 5000 rpms, where the high and low lobe on the cam produced almost exactly the same horsepower. My cam has the "low" changeover point programmed in (and I love it, thanks Sector111), even so, my exhaust note changes when the second cam kicks in, even though there isnt a noticable seat of the pants acceleration difference at the changeover point. Cam changeover will be extremely obvious in a stock car (I mean ultra-super-duper-crazy obvious).
Finally, If you cannot fully follow what I have written, you probably should not be tinkering with your wiring. I am not going to fly out to fix your car if you smoke your ECU or wiring.
