1 - 7 of 7 Posts
The driver side power window button fails frequently. Then all the sudden it works fine. At first I thought the contact was wearing out, but when its working, there is no sign of any problems.
Has anyone replaced the power window switch?
Was it burned out, broken, or did it look fine?
Thanks!
2006 na exige
I had the same problem. just remove the screws in the top of the door panel and check that the wires are pressed into the switch firmly. I was told the often come loose. Most likely excessive g force!
Super Moderator
Yeah, check the connection at the switch. The connectors have been known to loosen up and sometimes the individual wires can back out of the connector.....these are obviously high quality components! :rolleyes:
1 - 7 of 7 Posts
