1 - 6 of 6 Posts
just curiuos if anybody have this problem with the power window switch on passenger side..it wont go up dont know if its loose wiring in the switch or motor.dont think its the track cuz sometimes it will go up some times it doesnt..(06 exige) how hard is it to open up the door panel?
thanks in advanced;)
My passenger side switch went bad (bad contacts.) If pressed at the right angle it would work, but it was getting progressively worse. It was replaced under warranty.
It's very easy to take the door panel off. Remove the 4 hex bolts and one expanding plastic screw and its just velcro'ed in place.
You'll be able to reseat the switch on the panel to see if that's the issue. You can also remove the switch from the door panel and try it on it's own.
1 - 6 of 6 Posts
