With all the Kevin Brown craziness/hype going on, I thought I would make a nice thread showcasing the results you can achieve using his method using a rotary which is slightly different from his method with the foam pads. I have been working with Kevin for the past couple weeks trying to perfect this method, now I just need to get a DA so I can finish it off! For some reason I have not been able to get a ZERO hologram finish using my rotary and M205 or M105 on a finishing pad. I spoke with both Kevin Brown and Jason Rose today on the phone, thanks to Kevin once again for the contact. The first thing Jason pointed out was that I was not using the new Soft-Buff 2.0 Finishing pad which M205 was specifically designed around and apparently does not play well with others UNLIKE M105. Not even other Megs pads, I was using both the Soft-Buff(non- 2.0) Yellow and Tan and could not get the desired results I was looking for. I even tried both M105/205 on black Lake Country Finishing pads with even worse results. I was running out of time to experiment with my new bottle of 205, so I ended up finishing with 3m Ultrafina on a 3M UK Finishing Pad. I will be purchasing some more 2.0 pads and give it another shot. Once I get my DA, I am positive I will have a better experience as well. WARNING: If you are not open to learning new skills, please press the back button on your browser. :hide:
What I have learned:
-Kevin Brown IS THE MAN!
-The KB method DOES INDEED WORK! AND VERY WELL!
-You can almost get LSP ready results even using a heavy wool pad, of course this is dependent upon the paint, but even on the softer paints with a foam cutting pad you can achieve great cut and an even better finish!
(my new favorite is the Megs Soft-Buff 2.0 Burgandy FOAM)
-M205 apparently is pad temper-mental. Im going to give it another go with the new pads and hopefully Ill get me G110 this week as well!
This is how the car looked when it arrived..I got this 2001 Mercedes SLK230 two days ago, and we'll just say it wasn't in great shape...AT ALL! In fact, the paint(specifically the trunk)was in probably the worse shape I had seen. I was only hoping and praying M105 would be able to tackle it even using the KB method.
