1 - 2 of 2 Posts
I am selling my Proalloy fuel tank. This is a drop in replacement of the standard 42 or 38 litre OEM tank.
I have fitted a VDO fuel sender.
The advantages over stock are as follows.
1) An extra 18 litres capacity.
2) E85 compatible foam filled which prevents fuel surge.
3) Non return valves to a small compartment that the fuel pump is situated. This means that you can run a much lower fuel level on track before worrying about fuel starvation and catastrophic lean out.
4) Significantly lighter that stock.
5) The fuel level can be from the stock sender that reads full at 42 L or read 0-60 L with a VDO fuel gauge .
Asking $780 and this includes freight from Australia.
60 Ltrs Anti Surge Pro Alloy fuel tank (Elise, Exige, 340R, 2-11, VX220, Exige V6) [PALRT60S] - €819.99 : Elise Shop, Performance parts for your Lotus Elise
VDO Fuel Dip Tube Senders & Gauges
Discussion Starter #2
Sold
1 - 2 of 2 Posts
