Yes there is:
MODIFYING ALARM WHILE CDL REMAINS OPERABLE
1) Immobilizer - Wires that terminate at immobilizer plug terminals 1 & 6 (fuel pump) and 5 & 12 (starter) to be splice together (1 to 6 & 5 to 12). Immobilizer plug must remain connected.
2) Microwave Sensor – Disconnect all wires a Microwave and insulate ends.
3) Directional Indicator Lights – Disconnect Alarm Module wires, GW (green/white) from terminal 5 and GR (green/red) from terminal 7.
4) Siren – Leave all external wires connected. Remove screws and remove panel to gain access to the internals. Disconnect the two wires that go from the circuit board to the speaker & insulate ends.
5) OPTIONAL (without this modification these three switches will still trigger an alarm) – Trunk & Front Access Panel Switches – Disconnect Alarm Module wire RK (red/pink) from terminal 21
6) OPTIONAL (without this modification these two door switches will still trigger and alarm and the interior light will not operate automatically) - Door Switches – Install a 1k resistor between the Interior Light P (purple) wire and the Alarm Module PW (purple/white) wire, terminal 9. Cut and insulate the same PW (purple/white) wire after the resistor connection. Order of connections in PW wire; “cut”, “Resistor connection”, “Alarm terminal 9”.
Michael
Maybe I'm too stupid (or smart) to follow these instructions. I've tried several combinations and can't get my immobilizer disabled and still be able to start the car.
Steps so far:
1) I spliced the 1&6 and 5&12 wires from the immobilizer plug together. I cut the wires on the car side (not the immobilizer side) and spliced them there. The wires from the immobilizer side are open circuit.
2) I disconnected the plug on the microwave sensor.
3) I did not do this step. Is this necessary?
4) I have not disconnected this yet. It's inside the left front wheel arch, right?
5) I cut the wire red/pink on the alarm module plug.
6) I did not do this.
I have not spliced the brown and purple/pink wires together yet to get the flashing LED.
What I want is: the flashing light when the doors are locked, the fob can lock/unlock the doors, but if that alarm every goes off again for any reason I'll start tearing parts off until to stops! I (and my wife especially) am tired of the car getting lonely in the middle of the night and crying for attention.
Symptoms:
With the alarm plugged in when I lock the doors the alarm sounds immediately.
With the alarm unplugged the LED is off, but the car will not start. And the CDL doesn't work.
I tried plugging and unplugging the immobilizer plug and the alarm plug in every permutation.
I know there are a lot of questions here. Can you guys help?
Thanks,
Rick
