1 - 15 of 15 Posts
I was stopped at a traffic light around 9:30 tonight when some kid in a Toyota Corolla in front of me decides to put his car in reverse and back up. I leaned on the horn but he keep going and hit me. He claims he didn’t see me. Has anyone recovered from this much damage and what can I expect? Many thanks, all.
I can be fixed, might get pricey if the crash structure is damaged.
I would personally try to make it so they don't total it
Waht is it with people backing up in the street..........
Ouch. On the plus side, while the clam is off, you can install a better horn.:|
Whatever do you mean???
um.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
https://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
https://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
https://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
https://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Administrator
2010 Exige S260
Clam can be repaired by a proper fiberglass expert.
Will send you referral to the best shop around.
2005 Elise LSS Saffron Yellow
and fix/improve the HVAC... I have no idea what the solution is for this level of idiocy, but it's obviously a problem. Just in the last year several elige owners have reported morons backing into their cars despite honking horns and flashing lights. Good luck with the insurance. And for the record, "I didn't see him" is an admission that he was not aware of his surroundings.
I wouldn't anticipate any issues with the other driver being at fault. May as well consider the radiator if it is stock. I'm planning to put in a pro alloy from BOE this winter.
I would add to the list of "DOs".
Avoid placing your Elise/Exige in a position where it can't be seen by the other driver(s). At stop lights ALWAYS make sure you can be seen by the other driver in their mirror(s). For example, don't pull up so close behind a pick-up truck that you can't see the driver's eyes in at least 2 of their mirrors. This may mean stopping further behind than usual and off to one side.
Kiyoshi
P.S. This is a clam replacement. Hopefully no damage to the crash structure (which would mean a write-off).
Weirdly, I don't remember seeing anyone back up in traffic in my NJ/NY/PA area.
But, no one doesn't hear my horn.
(Khamai has great info in his post.)
Flashing lights: no value if person doesn't look or see you.
In Toronto, I often see people back up at intersections. They pull into the intersection or across a crosswalk and then the light turns red and they back up.
As my "Notes" say, I drive with my finger on the horn buttons.
So sorry to see this happen to you, I know the feeling
:frown2:
In 2009, my Lotus was hit by an airport shuttle driver, taking out my clam and crash structure. No fault of mine.
There was no chassis damage only the carbon fiber crash structure and fiberglass clam and radiator.
That said I took it to an authorized dealer repair facility, it took 6 weeks to repair (mostly due to the availability of a replacement clam and the crash structure from the factory) The total bill was $28K.
Since it's the other drivers fault (and I assume they have insurance) you'll likely get push back on their insurance, however they shouldn't total - and at least in the state of California, they are responsible for putting the car back into usable form or finding you a replacement. You or your repair facility will find this the biggest stumbling block these days as the factory doesn't build these in any regularity for the last 5 years or so. There are several sources for rebuilt/refurbished clams, not too sure on the crash structure... Text me if you need links for sources.
They may ask you not to use authorized repair facility, however I would recommend holding tough on this. If for some reason they balk at the repair cost through authorized repair, then make sure they suggest and guarantee the work for alternative.
I've only had one insurance company (in roughly 5 incidents) not work with me to get it repaired at the facility of my choice.
I wish you luck. You should consider putting an Aluminum radiator if you haven't already - to replace the lousy original equipment that tends to rust and crack.
Good luck feel free to reach out if you need any further advice.
A young lady in a Camry somehow accidentally shifted her automatic into reverse and floored the throttle and hit the front of my car. There was a guy standing on the corner waving a sign that apparently got her excited. Thankfully I wasn't driving the Lotus. As is typical, she bolted when the light turned green and I followed her to work some non-threatening distance behind. When I got out of my car, she claimed that she was late for work and that's why she didn't stop. Then she explained that she was a massage therapist and offered me a free massage.
so,... does this story have a happy ending?
1 - 15 of 15 Posts
