1 - 14 of 14 Posts
2006 Exige
So any idea where else to get these other than lotusgarage?
If I believe I have a bad o2, should I just buy 2 and have them both replaced?
someone suggested that the downstream o2 is only for the cat and isn't really important compared to the other one.
is there a DIY on this repair? i've never done it before nor do i know where to look and what i'll need.
I've been looking at these, too- (since I started getting an occasional P0133 code...)
It looks like a good replacement O2 sensor that would plug right in would be this:
Denso 234-5107
It's $165 from carpartswarehous.com, and $74.83 from myautopartswholesale.com
Is anyone using the Denso part, and is it as good as / better than the OEM Bosch? (The Bosch looks like it may be identical to the one used on the VW GTI.)
For the moment, I've swapped the my pre-cat O2 sensor with the post-cat one- If the code comes back I plan on ordering the Denso part...
Guys, I can supply the O2 sensors in good price.
Please PM me if interested. Thanks
Sent from my GT-I9300 using AutoGuide.Com Free App
There are multiple narrowband O2 sensor technologies, and our ECU is programmed for the technology the stock O2 sensor uses (for example, response times can vary for the same conditions between different types of O2 sensors). If you pick a different one, you need to make sure that the technology is the same, otherwise you may get poor running or and check engine light.
I would also love to have a list of compatible alternative cheaper O2 sensors. I wouldn't mind universal sensors that you have to splice in the old connector (I'm good at that).
Does anyone have a list?
I installed the new O2 sensors I bought here (thanks, Dori-Dori!) and haven't had a CEL since- it seems my pre-cat sensor was the problem.
2006 Exige
bringing back old thread of mine.
i'm thinking of picking up a bosch o2 sensor since some other members tried this and said it worked. i'm assuming this one you have to do some splicing to get it to work with the oem set up.
bosch/oxygen sensor part number 15733
Bosch/Oxygen Sensor (15733) | AutoZone.com
I believe that is what I have installed. I just matched the wires and used solder and heat shrink. No problems so far. Just be sure to cut the old sensor furthest from the harness so you can reuse it again later down the road, since you'll have to remove the soldered part later on to get good clean wire.
2006 Exige
i'm about to have this done. installing the bosch o2 sensor. and hopefully get rid of this dang p0171 code.
when you say furthest from the harness, are you saying closer to the oem o2 sensor?
Yes, you want to give yourself some extra length on the wire itself, so cut it closer to the body of the oxygen sensor. This way if you want to replace the sensor again in a couple years and you have to cut harness you will still have plenty of length in the future.
Is 15733 the ticket ? 2005 Elise
Yes that is correct. I bought mine from MWR and it was identical.
I've got the sensors, are y'all using the included Bosch screw together connectors or something else?
1 - 14 of 14 Posts
