1 - 13 of 13 Posts
Soemthing I have been meaning to ask you all is:
Are you supposed to have to depress the clutch pedal to be able to start your Esprit? I can start my car by just turning the key; don't have to depress the clutch at all.
Every manual car I have owned had this safety feature. My 93.5 Esprit does not. Maybe it was bypassed by the PO; maybe it was not a safety feature from Lotus. I thought it was a US DOT mandate though.
I don't have to press the clutch or brake to start my 98 V8. And I don't get any alerts when I am not wearing my seatbelt.
Maybe that's all part of the exemptions that Lotus was using to bring in the Esprits.
No need to depress clutch (but I do) to start my 2010 Evora, so it is apparently not a U.S./safety mandated item. Many other, older, manual-equipped cars I have owned did include this clutch/ignition inter-lock.
interesting.
thanks for the reposnses. I think I have owned 5 other manual transmission cars in the previous 21 years, and they all had to have the clutch depressed to start them.
Less is Better
The Elise doesn't have a clutch switch either. Maybe Lotus thinks it's drivers are able to start a car without slamming into something.
I think this "idiot switch" was added in general some time after 1982, my Rx-7 doesn't have one. My 91 MR2 does, though.
German Reimport
I think this "idiot switch" was added in general to cars sold in the US some time after 1982, my Rx-7 doesn't have one. My 91 MR2 does, though.
I fixed that for you
My wife started my lotus while it was in first gear, clutch engaged. The engine started, the car moved, and away we went.!!! I am not joking.
It could be that Lotus actually realizes that having the clutch depressed when you initially crank over a motor is a great way to have premature thrust issues (crank walk)
I disable the clutch switch on all my cars, and was happy to find I didn't need to on the Esprit
Super Moderator
interesting.
I've owned at least 10 manual cars... none of them have had a clutch interlock :)
I did once drive a Hyundai and couldn't figure out how to start it for ages... it had one... what an annoying, interfering, useless addition to a car :mad:
It was not a US mandate in 1993.
My 2005 Elise has no starter/clutch interlock either.
Negative on mine
Yep - and the spigot/input shaft bearing is already an issue on the older G Esprits as it is.
No need to touch the clutch pedal unless you are changing gears.
1 - 13 of 13 Posts
