1 - 20 of 27 Posts
The universe doesn't hang in balance here, but this has been puzzling me for some time now.
So here's the quandry boys and girls:
This bag of ice melt salt has been sitting in this same spot since it was used last winter. For the past several weeks, maybe months, there is a puddle of water under it. The puddle is ALWAYS there. It might ebb and flow a bit but not much. There is NO water source anywhere near it. Water is not flowing there from any place else. I am completely stumped by this.:shrug:
I don't know what the numbers are but it's been anywhere from muggy to very comfortable. Temps ranging from 50-60 at night to 75-85 during the day. The puddle stays the same wheteher it's cool and dry or hot and humid.
Edit: I wonder if it's sucking the moisture out of the concrete. I'll try moving it to a different spot and see what happens.
...pour a cup of water onto your doormat - where does it go?..if that door's as trafficed as the debris suggests, i suspect that might be the local low point on your slab...
But that would suggest water is flowing to it and it's not. That mat does need a good shaking out though.
Perhaps it absorbed water while it was cold out and now that it is warm, the water is coming out?
I would think just the opposite as the humidity is low when it's cold. I have a humidity and temp gauge next to it now - gotta give it time to stabilize. Currently 73F and 49%RH
I have thought about tasting it to make sure it really is water, but I'm sure it would be salty either way.:D
perhaps condensation is forming on the outside of the bag when the temperature swings from cold to hot
I think salt has a pretty high specific heat(maybe I am thinking of just sodium) which would make sure it stayed cool when temps start to rise
Discussion Starter #12
Interesting...........there are small droplets of condensation on the top of the bag where there is no salt. Perfectly dry down where the salt is.
Now 72F and 54% RH.
not sure about the spelling, but it's called efflorescence....
the salt picks up water vapor from the atmosphere and melts, dischargeing water.
it's a problem in numerous chemicals.
i take it that the bag is not totally airtight.
sam
I stored a wood table under my bed for several years. The house was built on a concrete slab. When I pulled he table out, some of the edge-glued boards had come unglued and warped slightly. I figure moisture in the ground had diffused through the concrete and the into the wood.
Try moving the bag to a different location or put a tray under it to see if that makes a difference.
The water has to come from either the slab or the air. Isolating the bag from the slab should give you a partial answer to your question.
Discussion Starter #16
That was exactly what I was going to do. But I think Zammy nailed it - the salt is absorbing moisture from the air, melting from it, then not being able to retain as much water and is giving it back up.
Now at 68F and 68% RH.
And, remember salt will absorb more water at a higher temperature then give it back when it gets cooler. How much easier is it to get sugar or salt to dissolve in a hot liquid then a cold one.
Same thing happens to me with a partially used (open) bag of this stuff. Eventually the individual crystals will fuse together and form a big useless lump. Seal up the bag or throw it away now.
1 - 20 of 27 Posts
