If you have been following my other threads you know that I moved from Philadelphia to Portland Oregon and my Lotus had somehow sheared off all mounts between the engine/transmission and the frame. I am happy to report that the repair shop in Portland was able to reconnect the engine to the frame and all is good. HOWEVER....
When he called to tell me the work was all done, he said he needed to talk to me about the car. He said almost ALL the bolts were either loose or just hand tightened. He tightened everything but found it strange and asked if I had worked on the car recently.
Well the past year my car has been in and out of a shop that I have used for several years. I actually only got to drive the car about 5 days the whole year because it was back and forth to that shop. The major items were the gas tank replacement and head gasket replacement. Don't you think its odd to have all these bolts loose? I don't want to mention the name of the garage in the Philadelphia area in case they were not at fault.
What do you think? Was the shop in Philly doing shoddy work???
