1 - 9 of 9 Posts
I just had my car aligned and corner balanced yesterday. According to the data sheet both left and right sides of the car have the same ride height and maintaining about a 1 degree rake. But when I look at the rear fender gap one side is higher than the other. Does this mean that my rear clam may not be sitting level?
Administrator
Depends when they corner balanced did they pre weight with 160# both seats as suggested by Lotus or just preload with your body weight in drivers seat?
if they balanced with you in the car (weighted) I’m sure they preloaded one side more then the other to make the corner weights correct, as a result when the car is unloaded, there extra preload is represented as increased (read different) ride hight on the corners...
Less is Better
It is VERY likely that the clam isn't completely even on both sides. Measure the distance from the ground to a chassis point and then the ground to the wheel arch. If it's difference is not the same left to right, the clam isn't even. I suspect most cars are uneven to some degree.
2006 Lotus Elise BRG
I'm doing this now. The ride height is noticably different with and without the ballast in the car.
Administrator
All cars and setups will be a compromise and I was lucky enough to have the club scales for a week and played around with various wheels and weight combinations. I determined that the PO probably had it corner balanced with 175 and 160 in the seats and it was so close I left that alone. I did have 2mm added to the rear so I would be 5mm differance between front and rear. I set my LSS wheels at 128/133 and the 15/16 track setup at 120/125 when setting the camber and aligning after I installed V2 arms in January. Can't wait for a track day but on my epoxy garage floor it spins easily with one finger and the touch and feel at low speeds is so much lighter.
Administrator
Dup
Administrator
Then it's fine with nobody in to lean slightly.
1 - 9 of 9 Posts
