1 - 5 of 5 Posts
Hi,
The fuse to my cigarette lighter socket just blew, can I take the fuse from the horizontal row (same amp of course) ?
I assume those are not in use?
Thanks!
Show us a picture of the cover which shows what the fuses go to. Looks like the center row is just spare fuse storage but shoot the picture just the same. Which model and year?
Oh, this is the fuse box under the cover, in front of the windshield. I looked in the owner's manual, and the one that blew is for "aux power" (upper left corner in the photo).
My car is 2006 Elise.
Thanks,
no headlights/no taillights 05 elise
05 elise same fuse box so I userd 10A center row to replace f16 10A - but only driver side headlight came on and passenger side headlight and both tail lights still don,t work - all other lights work :frown2:
If you'd pulled a fuse from middle row, you'd see if there were metal contacts below it or not.
If not, it's a spare. Keep a bunch of diff fuses in your car.
mid-life, so your parking light stopped illuminating, so you replaced that fuse?
check the fuses for what doesn't light up with a digital voltmeter/multimeter. (Visual inspections don't always tell the truth.)
There are great for use around the house and in the cars, and inexpensive.
Main fuse box
Slot Rate Circuit
1 20A Aux pwr socket
2 5A Reverse lamps
3 20A Driver’s window
4 20A Pass. window
5 10A Stoplamps
6 7.5A Turn indicators
7 10A Ignition services
8 7.5A Battery services
9 15A Hazard lamps
10 7.5A Horn
11 10A Alarm pwr, interior lamp
12 10A ABS
13 3A ECU Ignition
14 20A Rad. fans; 1&2 slow, 1 fast
15 7.5A Radio, switch pack module
16 10A Parking lamps
17 10A Dip beam LH
18 10A Dip beam RH
19 20A A.C. comp. relay, rad fan 2 fast
20 15A Main beam LH
21 15A Main beam RH
22 7.5A CDL
1 - 5 of 5 Posts
