1 - 6 of 6 Posts
Vendor
Used Race-Keeper HDX2 Multi-Camera 1080p HD Video-Logger in excellent condition. This is the most expensive package they offer and includes two 115 degree cameras. Here is the description from the Race-Keeper website:
The Race-Keeper HDX2 is one of the highest specification video-logging systems on the market. It is supplied with 1080p HD cameras, 20Hz GPS and OBDII/ECU connection capabilities.
The Two Camera version of HDX2 is the default product for most club-pro level racers. When the 1080p HD cameras outstanding picture quality is combined with the speed, trackmap and laptime data derived from the 20Hz GPS signal and G force data from the systems built-in accelerometer, you end up with an extremely powerful driver development tool that will show you all you need to know about driving lines, braking points, turn in points, apex clipping and more.
Most professionally built race cars have custom ECU’s or Dash Displays that are capable to supplying the data it captures to additional devices using CAN communication, meaning you will not need to double up on sensors in order to measure the same parameters. The additional driver data channels you would want to capture via CAN would include:
  • Speed
  • RPM
  • Throttle
  • Steering Angle
  • Gear Position
  • Brake Pressure
HDX2 is CAN enabled as standard and will support connection to a number of standard ECU’s manufactured by Bosch, Motec, Pectel and MBE. It is also possible for custom CAN protocols to be created so if you are interested in adding these extra data channels to your system but you are running an ECU that is not currently supported, you can import .dbc files straight into Comparo HD for use with HDX2.
The ECU’s on all modern road cars, and therefore some racing cars, transmit signals using the “On-Board Diagnostics” communication standard OBDII. By connecting your Race-Keeper HDX2 to the OBDII on your car, you will gain some data channels in addition to those from GPS and the built-in accelerometers, the main ones being Speed, Throttle and RPM.
These additional data channels will allow you to further analyse your on track performance and see where improvements can be made.
This costs $2,989 new.
$1,950+ Shipping
Email [email protected] or PM me
DSC_0093.JPG DSC_0094.JPG DSC_0095.JPG DSC_0096.JPG DSC_0097.JPG DSC_0098.JPG DSC_0099.JPG DSC_0100.JPG
1 - 6 of 6 Posts
