Take it from fuse C3 and route it to the rear of the cockpit.I've seen threads on tapping switched power from the radio, ignition switch, fuse panel and engine start panel. Are there any accessible switched power sources in the rear cockpit for wiring up a rear mounted radar detector? If not, what is a good way to run power wire from the front to the rear, under the door sill protectors?
Michael
