1 - 10 of 10 Posts
Where are you located? I may be interested if you are in Florida.
If you are putting this in, I strongly suggest that you have a radiator specialist install a bleed screw in it. I have a 2005 Elise and had the dealer put in an all-metal radiator during a recall for oil cooler stuff. If I had realized then the insane place the bleed screw is located on my Elise, I would have had someone put a bleed screw on the rad itself. I can SEE the corner of the rad when my car is parked. It is a simple matter to remove the rad-exhaust grill to reach this area.
When Lotus designed the Europa, they put the bleeder directly on the rad in a spot easy to reach. How did they forget to be that smart?
Is this still available?
I don't think so. We both want it but no response by email and PM will not work. I need a radiator because mine is leaking but no response!
[email protected] :surprise:
1 - 10 of 10 Posts
