Hi there! Why not register as a user to enjoy all of the benefits of the site? You may register here. When you register, please pick a username that is non-commercial. If you use a name that appears on any search engine commercially, you must pick another name, whether it applies to you or not. Commercial usernames are for supporting vendor use only. If you want to become a supporting vendor and grow your business, please follow this link. Thanks!
I’m not sure if this should go under electrical. I recently replaced the SPAL fans in my ‘06 Exige I matched the wiring exactly. Previously, one of the fans was not turning on and the car was running hot (207°) after spirited driving. I replaced the fans and now they both run non-stop even when cold. I searched the forums for similar issues. I don’t want to rig up a switch and I want to rectify the problem properly, thoughts??
It looks like I should go with replacing 1: the ECU temp sensor then test, 2: the fan relay pack then test, 3: the trinary switch after evacuating the A/C system then test.
Quick question is your AC on when the fans are running? I can't check my car's on jack stands right now but it seemed to me that if the AC was on the fans were always running...or I could just be getting senile lol I can check later in the week when it's all back together.
I 'think' you can get to a bunch of the wiring without pulling the clam
Related Threads
The Lotus Cars Community
2.7M posts
51.5K members
Since 2002
