Having trouble with posting to existing threads and then showing up as new. Doesn't seem to be working for me so here is a new thread.
I finally completed the radiator and hose replacement. Temperatures are good and and header tank is still settling in with its level. One thing that is a little puzzling is a very slight weep of coolant at the bottom of the sway bar mount. Above the mount is the radiator hose connection. However, no signs of leak from above. I suspect this is spillage from removing the old radiator hoses and draining the system. There was definitely some spillage. How long will the coolant take to dry up? I went for a 100 mile test drive on Monday and the weep showed up again last night. I cannot see a path for the coolant so must be spillage working it's way from the mounts. The mounts are two pieces of aluminum bolted to the tub with the sway bar in between. There really is no source for coolant to get there unless the hoses are leaking and there is no sign of a leak from above.
The back of the sway bar mounts don't appear to attached to the enclosed area with I believe contains the heater matrix. Just hoping it's spillage weeping (for day's now) and not something else.
