1 - 5 of 5 Posts
Hi all, I am having a problem with my rear caliper,it will not tilt back. I removed the bolt,and pulled the slip lock out,but the caliper will not go back,has anyone had this trouble? I did the front brakes no problems,then I started the back,and this happen. My car is a 2005 Lotus Elise,any help would be great. Bob
I had some stick last time I did a change - rotors were a bit grooved and had a lip and the pads stuck a bit to the pistons. The combo of the groove and the stick prevented the caliper from rotating freely.
Pulled the bolt, pin, spring, then tapped the pads very lightly with a hammer and the caliper rotated.
Remove the o/s pad first, then easy to tilt/swivel.
try the easy move 1st, it worked for me well today.
let us know how you make out.
1 - 5 of 5 Posts
