Hi.
I'm trying to remove the rear clam of my 08 Exige.
I have several problems for which I can't find the solution alone.
anic:
I hope you could help me...:bow:
Problem 1: the fuel cap
I have remove all the allen screws around the aluminium ring but I cannot take this out.
It seems that it is "glued" to the body and I do not dare to use some tools on the edges to take it out.
If I leave it mounted unscrewed, will it get off together with the clam?
Problem 2: the speakers panel behind the seats.
that is really the wall for me! :wallbang:
I learned that I should take this out for removing screws behind this panel.
The problem is as you can see in the pictures below that I cannot remove it as the Lotus harness bar in in front of the panel.
I removed the seat belt fixing point at the top but still could not go get access to remove the harness bar...:drool:
So please what are the next steps??????
Thanks for your help! :bow:
François
François
