I noticed a gap around the bottom of the hatch rim that wasnt there before. Appears it doesn't seal as well as it used to. Still locks but something's off. small scratch at the top of the rear clam from opening the hatch. When the latch is pulled, no more pop, I have to hold the latch in and pull the hatch open. Checked the hatch latch mounts and those are tight.
Anyone encounter this issue?
changed the header and larger wing mounted in stock position. Wonder if the increased heat or movement from wing had an effect...
any ideas?
thnx
any ideas?
thnx
