1 - 6 of 6 Posts
I was investigating a squeek that sounded like a pulley bearing or sumthing like that is it's sound varried with RPM. I removed the belt to have a see if any of the pulleys were loose or there was obvious play in any one of them. I found that the rear most idler pully had a fair bit of play in it. Last time I changed the belt I did not notice it (last year). Does anyone know if this is normal, or what the tolerance should be?
I think there was a recent post about a TSB on idler pulleys. Did you search?
Yes I looked. The TSB is on the tensioner pulley assembly. I just put a new belt on so I will see if that helps. Will see
It could be your Tripoint kit pulley bearing, there have been several that have failed. Send a PM to turbophil...he makes an improved one.
Thanks Dave...I will drop Phil a line.
I did check that as I thought it may have been the issue but so far it has less play than the other Idler pullys (OEM ones).
Saffron Yellow is Lighter
What did you find out about your loose idler pulley? I wish there was a way to delete this pulley all together.
1 - 6 of 6 Posts
