1 - 17 of 17 Posts
· Frankesprit user
Hi, I have a bent lower rear link. They're pretty thin wall tubes and I'm a bit worried about structural integrity...has anyone straightened one?
From my research on the superseded numbers, are the lower rear links the same from S3/Turbo til the latest? Looking at my options used versus new if I buy another.
Thanks, Rob
· Wingless Wonder
1988 Esprit Turbo; 2005 Elise BOE Supercharged
I've seen some bent lower control arms, I'd be inclined to replace rather than attempt to straighten them. Even if you THINK they are straight, the length may have been compromised.
Bending usually happens if the car is jacked or flatbedded via the control arms. :no:
· Wingless Wonder
Vulcan Grey made his own adjustable upper links. Search for the Topic or shoot him a PM.
Are you fitting S4/V8 wheels? If not, you don't really need adjustable upper links. The taller 15" tires are not as fussy as the low profile tires.
I have custom made upper and lower adjustable aluminum links with spherical rod ends. Dropped a couple of pounds compared to the stockers. Allows me to adjust camber and toe without having to fiddle with the ridiculous shims at the front of the trailing arms.
Nice Travis! You should sell those! or do you?
· Frankesprit user
Discussion Starter · #14 ·
I have checked yours out Travis. Those uppers are exactly what I want. Did you make the threaded inserts or get them from somewhere? I think the adjuster might be available at Speedway Motors.
Thanks, Rob
I just re-read that you bought right and left taps, so that answers my question that you made them. Those are really nice..
The threaded adjuster turn-buckles came from Lotus, they were standard on the X180-R. Lotus had a similar part for the 94+ cars with adjustable camber, but a different part #.
I used the left and right hand taps to make the stainless steel inserts that I welded into my cut upper links.
1 - 17 of 17 Posts
