1 - 8 of 8 Posts
I'm doing the 2pot caliper to rear mod, and need a radial mount bracket for the rear. I ordered the BOE bracket, but it's backordered right night and I have some events coming up. Anyone have any experience with the bracket on eliseparts.com? I plan to use the stock calipers for the handbrake if that makes a difference.
Thanks
@SeniorDingDong What did you end up going with? I'm getting ready to order caliper mounts as well and can't decide. Noticeable price difference between the two, but I can't tell if there are any other differences.
2010 Lotus Exige S260 Sport
Elise Parts uses 7075 t6 aluminum, BOE has 6061 t6 aluminum. That’s the only difference I can tell. Hope this helps.
Since you are liv8ng in US, I suppose, I suppose that inokineric have some. Since I am in Canada, I am using a lot eliseparts, nice service and nice product.
For the bracket itself, it is now a generic product...
I just bought the Boe brackets and installed them, the fit is perfect and they do have a cut out to clear the abs wires, others don't. I was toying with the idea of buying the Elise part ones as well, but the price difference, by the time you have them, is not worth it to me.
The one difference I see is that BOE has steel threaded inserts as per there web page:
"A very important note is that we installed steel threads so you know the threads will stand the test of time."
Another reason I went with the Boe bracket, they use Allen head bolts to fasten the bracket to the upright, they are counter sunk into the bracket and clears the joint on the axle, but just barely. The other brands use hex head bolts, and I can't say this for certain, but from what I saw installing the brackets, clearance would be a problem, and getting a torque wrench on them impossible, unless you have a crow foot that size. Remember they have to be tightened to 65 lbs/ft. ?
Yeah, I seem to recall older posts about that ABS relief cut out. I ordered the BOE mounts today as my gut tells me those will be easier in the long run.
Reactions: CRG53
1 - 8 of 8 Posts
