1 - 20 of 27 Posts
I don't know about everyone else but with less than 200 elises delivered, and 3 reports on this board about broken/cracked oil coolers dumping oil, I'm quite concerned.
Has Lotus changed manufacturers yet?
What does it take to create a recall?
Robert
Perhaps they are actually investigating the cause of the failure. Why change suppliers? Most companies would allow/force the current manufacturer to alter the design to avoid the problem.
Let's see why it is happening before we ask for a recall.
Greg
insert clever title here
No need to panic just yet. The fact that these are failing so early in the car's life in encouraging; it's almost certainly to be caught under warranty if it really is a widespread problem.
I think there is some investigating work and discussion back in Hethel about this.
You have to expect a few problems if you're one of the first to get a completely new car model. It's not exclusive to Lotus, the same thing happens to much larger manufacturers. That's what warranties are for. It's still a hassle, of course, but that's a risk you take.
It is almost a mantra in Porschephile circles to never get a first year Porsche. Recent examples that come to mind are 1995 993s (1st year) had faulty wire harnesses that lead to car fires, 1999 996s (1st year) had oil starvation problems during high speed cornering and some engines were lost and so on.
Don't panic over 3 oil coolers, all car manufacturers find during the first year the bugs they didn't catch during the development and testing phases, it is totally normal in ANY price car and more so in low volume cars. The more important question is if they fix the problem and let us know about it so we may get it corrected on cars that have already been delivered. Just so you know, the problem on the 95 993s even though widely known and can be corrected under warranty is still an issue one should look at when bying a 1995 993 since many cars still haven't had the wire harnesses replaced, and the 1999 996 oil starvation problem was corrected in the following year but as far as I know all 1999 cars are subjected to it and there is no easy fix for it. There are a lot more examples like these for all cars.
I wouldn't be so concerned, except for the location of the coolers. If one decides to let go under pressure and oils a front tire, serious mayhem may occur. I had a formula vee oil the track right in front of me yesterday :eek::no: and I REALLY do not want to go through that again - especially on my own oil.
This is clearly a concern. I hope Lotus looks into this carefully and takes whatever action is necessary to prevent these failures.
Agreed, I'm not worried that there are some bugs, but I'm very interested to see if they handle this any better than the rest of the roll out.
I'll bet that they are simply overtorquing the aluminum fittings during the build.
The push for quality control sometimes deprives otherwise skilled people of the self confidence and common sense.
The problem is that these fittings tend to be unforgivable.
I've seen this problem with Mocal/Setrab coolers.
m.
git,
This was mentioned in the oil cooler thread it was purely an assembly issue causing a slight leak at the fitting which would pool on the rubber padding on the bottom of the cooler, when the area was saturated, you'd get a steady oil drip on the floor. NO CATASTROPHIC FAILURES LIKE SPLITTING ETC> assembly process modified and they'll be issuing a bulletin on what vin range is POTENTIALLY affected. FWIW if it doesn't happen after the first few hundred miles you should be ok. You can give a squeeze to the rubber piece below the oil cooler, if it's oil soaked see your dealer.
Chris
Yep.
If you check the cooler fittings and they are dry, then they will never leak until undone or damaged.
Once the fittings are overtorqued and leak, then you cannot seal the leak unless you're able to goop it, as the aluminum is gouged (This is what I mean by unforgiveable- you can't undo the damage, basically). The aluminum is thick at the fittings so will not worsen due to oil pressure.
When you purchase an aftermarket oil cooler, you are exhorted not to overtorque the fittings.
If the cooler matrix itself is leaking, then this has more potential for a runny leak that would quickly saturate any absorbents. This kind of leak would worsen as the tubing is thin gauged and will be exascerbated by the 80+ psi on start up and the 68-70 PSI at cold and at cruise + full throttle. This flow amount is more likely to get under a tire.
m.
Having lurked on ET for some time before buying mine in August, I concluded that things like oil cooler leaks were early production issues. Guess what's in the driveway when I got home from work :eek: a small but growing puddle under the driver's side oil cooler. My car is 2116, January '05 build. Guess it's going on the tow truck to the dealer Monday, i.e. no driving this weekend :mad: At least not much leaked. Though the puddle's fairly large now, it was only down 1/2 to 3/4 quart on the dip stick. Does anyone know of cars built later in the production cycle with oil cooler leaking problems?
Is it really oil?
Could also be coolant. Radiators or hose-connections sometimes fail on these cars too. Recently witnessed a spectacular radiator end-cap blowout on an Opel Speedster. Great geyser of coolant emerging from the car... (ir was idling at that time)
Bye, Arno.
1 - 20 of 27 Posts
