1 - 16 of 16 Posts
Rarely drive my car at night but noticed that the lights look really dull and yellow. What new bulbs are out there that you guys have all changed out to?
Not interested in switching to HIDs or anything just a nice bright white replacement bulb for our cars.
Thanks
Hey Marc,
I recently switched to Sylvania's "XTRAVISION" headlights and they are very good (black and green box). Big difference over stock.
Nice bright light that is whiter than the normal yellowish lamps, but not annoyingly blue.
Low beam is H5006 (2C1 original)
High Beam is H5001 (1C1 original)
Got them at Pep Boys. These part numbers also apply to the "standard" lamps that are little more yellow, so make sure you get the ones marked "XTRAVISION" for the upgrade.
Hope this helps,
Kent
They should be white. You may just have some dirty/corroded connections that are reducing the voltage. Try cleaning them up, low voltage is going to mess up anything you switch too so you might as well try fixing what you already have first. You could verify low voltage with a voltmeter while the lights and motor are on. Should have at least 12 volts and no more than about 13.5
David Teitelbaum
Thanks Guys. Light are working fine but in comparison to modern cars the design is dated, same since the start I believe. Just hoping to pop in some new bulbs and get a bit brighter and maybe wider reach.
I have added super white bulbs (off eBay for $7/bulb) for one of my other cars that did not come with HIDs. It did completely modernize the look over the stock yellow bulbs even though the light output was about the same. I did the high/low and fogs. And they have been lasting just fine.
Hey Marc,
Hope this helps,
Kent
Kent- what year is your Esprit? I'm wondering if those numbers are good for an 83?
all this headlight talk has me thinking about custom building some bi-xenon projectors.. ...
once you have xenon projectors, it's hard to go back to halogen reflectors.
Is there a way to raise the Esprit's headlamps without turning the lamps on?
Hi Bob,
Mine is a 1999 V8. My guess would be that they are the same round lights used over a number of years, but I do not know for sure. Anyone else know?
I would assume they would be the same, but we both know how to spell assume..
The best way that I found to do this (and change the bulbs) was to turn on the headlights, and then disconnect the battery. Easy for me to do since I have a quick disconnect switch.
Then the pods are up and the lights are off.
While you are in there, best to make sure that the drain holes at the bottom of the headlight cavities are open and clear. One of mine was completely blocked and there was about a gallon of water stored up in there!
Espree- thanks for the reminder about checking the drain holes
No problem - it is worth doing while you're in there. I used a flexible retrieval device to grab the leaves and go through the hole, but a coat hanger or similar would work too (though might scratch a little). Here is the lighted claw (great for getting dropped screws and things too): Amazon.com: General Tools 70399 UltraTech Lighted Mechanical Pick-up, 36-Inch: Home Improvement
I had always wondered why there was always water spraying out of my headlights for days after I would wash it... Then I found the source!
It's a lot easier to turn on the headlights, disconnect the plugs to the headlight motors, then turn off the headlights. That way you don't reset the ECU and radio.
You also might want to look into upgrading the lenses. The M100 Elan came with some pretty horrible sealed beams. I ordered Cibie Highs and Hella Lows with Narva Rangepower+50 bulbs from Daniel Stern and the output has GREATLY improved.
Daniel Stern Lighting Consultancy and Supply
1 - 16 of 16 Posts
