1 - 2 of 2 Posts
Hello from Germany,
A friend of mine has an question to you...
First I have to say that he has a Rotrex supercharged Elise from 2006 with white dash and Drive by wire.
Last month he swapped the white dash against an AIM MXS. Now he would like to know if it's possible to reflash my ECU from the K-Line connection protocol to the CAN protocol so he gets more datas into the AIM from the ECU? This would be datas like IAT or Throttle position which are sent as standard by the ECU since 2008 on cars with black dash...
He contacted BOE often enough but no response comes back from then...
Regards
Sven
I believe Kold-Fire used to offer white dash -> black dash flashes and vice versa, but I don't know if their firmware was a white dash one with the CANbus data rate / message altered to make the black dash work or if it actually added the features of the newer firmware like diagnostics over CANbus.
Because you are in EU and you cannot get a hold of BOE it might be worth contacting Kold-Fire or Komo-Tec (KF distributor in EU) to see if they have any insights.
1 - 2 of 2 Posts
