Remove Broken Bolt
5885 9
Snapped off one of the gearbox fixing bolts - F#%&#&k. I bought a good quality bolt extractor - the largest one for the bolt diameter and now that's snapped off inside the bolt.
I think my only option is to try to remove the bolt extractor and drill out the bolt with increasing diameter drill bits until I'm close to the threads.
Any other ideas that may be easier and faster?
How it looks -
-Broken Bolt and Broken extractor inside bolt.
1 - 10 of 10 Posts
If it were I, I'd heat the bolt (and extractor) with a pin flame from an acetylene torch - heat only the bolt directly, let the housing heat by convection only. When the bolt is hot enough to boil oil, keep applying a good grade of penetrating oil to the threads as the bolt and housing cool. Do not use an oil containing graphite or fluorocarbon (Teflon®) based lubricant. When the bolt is cool try using a hammer and chisel to drive the bolt out with tangential blows - mind the gasket surface. When the bolt has been backed out far enough to grab it with vise-grips, do so and finish the removal.
A.J.
Keep in mind that you cant drill the bolt extractor. Pull that out first.
I've had a lot of success doing the following: Heat the casing (ie: NOT the bolt) with MAPP or Propane or similar until it's as hot as it's going to get. Now apply an ice cube(s) to the bolt itself. Before the bolt can heat back up, attempt to remove the bolt.
The theory is, the case will be expanded by heating it and the bolt should be contracted (or suffer far less expansion) by cooling it. I've used this in quite a few situations and it has always worked so far.
1 - 10 of 10 Posts
