1 - 20 of 31 Posts
I had my rearview mirror removed, and i love it! I highly recommend it.
I always wanted to remove the sun visors, but i thought it would be a pain.
As it turns out you can just pull them off!
Now i have 100% view out the windshield.!
yipee!!!!! i never understood what the sunvisors were for, everytime i tried using it, i would still remain blind
I removed mine about 5 minutes into my ownership. I then installed one of the little mirrors and even at 6'4" I have very good forward vision.
dave
Same here, I removed my visors before I drove mine off the lot. Just wiggle them while sliding toward the center of the car and off them come. I'm also 6'4" so this was a nice "mod".
Not the admin anymore
It's an amazng difference.....
You can unscrew the metal rods that held them too.
Just did this, it was so easy!
Having an s240 i also took the rear view mirror off, this really opens up the front view.
Sent from my GT-P1000R using AutoGuide.Com Free App
Cool - I just added some lightness. Thanks guys.
Old thread but the info is still fresh. I removed my visors a couple of weeks ago to clean off the stickers. Goo gone, mineral spirits, and a fingernail brush cleaned em up pretty good. Decided today to remove them from the car entirely, along with the silver colored metal rods. I used the 8 mm end wrench with a small nail shim method mentioned by others. I had to actually tighten them a bit to help break them loose. They came out very hard..position wrench over end of rod, push little nail in between wrench and rod, carefully turn about 1/3 turn, repeat. A ratcheting 8 mm end wrench would really speed this up.
Anyway, this mod really cleaned up the windshield and helped with forward vision out of the cabin.
You were lucky. Some have actually cracked the windshield trying to remove the rods.
San
Recreational Mechanic
I took mine off recently using the nail method, a deep socket 1/4" drive and a wobble extension. Easy peasy.
Sent from my Samsung GS7 using Tapatalk
2006 Exige
I might try this soon. Your method doesn't sound too dangerous to the glass. I was going to wait until the day I had to have my glass replaced, but I'd love to have those silver things out of there.
TO REMOVE THE RODS WITHOUT A CHANCE OF BREAKING THE GLASS
Get a soldering iron and apply heat to the rod,hold it there for a few minutes,this will melt the adhesive **** lotus uses in the threads,then simply unscrew it ,you can thank me when you have done this method :wink2:
I also relocated my sunvisors and rods to the bin where they were more useful shortly followed by the rear vision mirror which is also useless on an Exige lol
If you still want a slight visor,do as i did and put a thin strip on the top of the front windshield as below
What material did you use for the sunstrip? I'd like to do the same. Thanks!
1 - 20 of 31 Posts
