1 - 2 of 2 Posts
Relocating my battery over behind the passenger, so I wanted to remove the evap. People have said they do this without issue.
What can I all take out.
There are the 2 tubes that connect to the top of the canister. The big one goes down to the tank, the small goes to a service port, than to some sort of valve on the engine.
Then there is the valve mounted to the frame rail with a wire going to it.
What can I all remove? What do I need to leave?
Thanks!!
download the BOE rev400 instructions from their website in tech section. There is a very detailed write up on evap removal and will explain everything you need to know. Very straightforward process.
1 - 2 of 2 Posts
