Hey All,
Having trouble removing the front damper/spring assembly from my 400 as one unit. I'm looking at the Front Suspension Service Notes and it's unclear to me if I need to remove either or both the upper/lower ball joints from the hub in order to get the assembly out or possibly the upper wishbone's front & rear pivot bolts?
My tetris abilities have not found a way to remove the damper/spring assembly, with the upper top mount bracket still attached. I did release the ARB link to try and get the most up/down travel on the suspension but no joy.
Appreciate any guidance or input!!
