1 - 16 of 16 Posts
I'm reading through the service manual about the procedure to remove/replace the rear clam but they don't provide how many hours it takes for each step. It sounds pretty basic but I was hoping that someone that has actually done this before to install a supercharger or whatever can give some insight as to how long it actually takes and if there are any tricky points.
Is it a 2 hour off, 2 hour on job or 3 on 3 off etc?
Not bad the summary I got from the service guide is basically.
1. Remove the seats, take out all the plastic trim behind them
2. Unbolt the clam from the cabin, take off body colored trim piece, unbolt trunk lid
3. Do you have to take out the intake air box and fuel filler neck or is that just to take the side plastic sills out of it?
4. Unbolt the bolts in the trunk floor and loosen windshield wiper bottle.
Anything major that I'm missing?
Very brief summary (from memory): Move driver seat forward, unhook speaker wires, remove plastic housing covering rear wall. Using a long socket extension remove bolts from passenger and drivers side. Remove Hard or Soft top to access fixing bolts that secure roll bars cover.
Remove rear wheels and liners (plastic doohickeys). Unbolt clam fasteners.
Remove four bolts from luggage compartment.
Remove rear diffuser panel.
Unhook elect. connections (rear lights)
Unbolt hinge, engine lid
Lift clam and remove!
I tried taking the plastic out out from behind the seats and there was not enough room. I took my seats out.
You dont have to take off the filter box or the filler neck. (but you do have to take the filler door off). I took the filter box out to have more room.
So it sounds like if you know what you're doing it should be an hour job tops to unbolt everything and just pull it off. Is it hard lining it back up when it's ready to go back on? I was able to install the speakers without removing the seats when most people said you had to. I'm pretty skinny so I can fit my arms in there pretty easily.
Thanks for the advice so far guys. I wish sandsmuseum had a writeup for the rear clam with pictures like their front clam removal.
Discussion Starter #11
Once again, the search functino comes in handy.
This is a previous thread about removing the rear clam: http://www.lotustalk.com/forums/showthread.php?t=51971&highlight=service+manual
Pay particular attention to Randy's comments in post 12 where he adds actual information from having done the work.
Thanks, it didn't occur to me to try the maintenance section. I didn't get much under general discussion even with rear clam removal or rear clam as the title only search.
this would be a good time to desnorkel the intake. :)
Stan quality ;)
Discussion Starter #16
Akandok, you wouldn't happen to have a picture by picture write up on this procedure would you? It must be nice to build the car up from the ground so repairs are easy in the future.
1 - 16 of 16 Posts
