1 - 4 of 4 Posts
I know the exige can be a convertible, but the lotus dealer said that its not a easy task. He also said that it wasnt somethng you could do with out special tools. How hard is it to remove and what tools does it take?
Your lotus dealer is an idiot.
Ive done it in probably under 3 mins using a normal hex key....its just 4 bracket bolts and three headliner to remove/loosen (headliner)
To be correct you need a torxs key available at most good hardware stores - but a normal hex key works at a push if the bolts arent tight
Your car also comes with the correct tool in a toolkit that is in the trunk (or boot). It should be either attached to the carpeting or in the little side pocket of the battery cover.
1 - 4 of 4 Posts
