In case anyone has a problem with the switches used for the lights, AC and recirc, here is some replacment information.
The switches are made by APEM components APEM : Professional Switches and Membranes
The switch series is IP http://www.apem.fr/pdf/uk/section_b/08-Serie IP-A.pdf
Part numbers for stock replacements is IPR3FAD followed by color options. eg IPR3FADLOG has a green LED. Cost is $20-$30 from Digikey. Cost is $70 - $80 from Lotus Garage, but that presumably includes the right wiring connector.
I replaced some of the switches with the latching version (IPR1FAD2xxx) so that my AC and recirc switch setting have more than a goldfish memory. eg I don't need to press the AC and recirc buttons every time I switch the fan off and then back on. Note that you cannot use latching switches with the standard switch pack module wiring.
